Could not reach temperature anymore after changing configuration
I used the original binary-file of my printer (Micromake D1) so far, but I needed to change the Z-Probe-logic. After uploading the changed firmware the Extruder temperature gets stuck at 238.4°C. What could be the reason for this?
Best regards,
Sven
  • Check with host/server to see if heater is being used 100%. If not there might be a limit set (normally 275°C) you might also have limited power to less then 255 (=100%) so it can not heat any further. Normally you can change these in eeprom settings.
