PNP photoelectric NO Z-probe
Hi, I'm trying to use a photo electric proximity detector as my Z-probe. The photo electric proximity detector is a PNP, normally open. When triggered it goes HIGH.I have it connected to the Z min end stop, pin 18 and have Z min hardware end stop set to false. I can't get it to work, it does not stop the extruder from moving down.Any ideas?. Here's my Z-probe config's
Thanks in advance for any help.
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE true
#define Z_PROBE_BED_DISTANCE 195 //CHANGED 5 TO 196
#define Z_PROBE_PIN 18
#define Z_PROBE_PULLUP true ////////////////////////////Jim
#define Z_PROBE_ON_HIGH 0 //Jim changed to 1
#define Z_PROBE_X_OFFSET 30 //JIM
#define Z_PROBE_Y_OFFSET 10 //JIM
#define Z_PROBE_SPEED 30
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 5 //changed to 10. This is the distance that it moves up between the 5 bed distance checks
#define Z_PROBE_REPETITIONS 3 //jim
#define Z_PROBE_HEIGHT 5 // jim CHANGED TO 5
#define FEATURE_AUTOLEVEL 1
#define BED_LEVELING_METHOD 0
#define BED_LEVELING_REPETITIONS 2
#define ENDSTOP_PULLUP_X_MIN false
#define ENDSTOP_PULLUP_Y_MIN false
//Z PROBE connected to Z min endstop using PIN 18
#define ENDSTOP_PULLUP_Z_MIN false //jim false to true
#define ENDSTOP_Z_MIN_INVERTING false //jim true to false, photoelectric Z probe 12-10-16
/* Added by Jim
this setup assumes the TOP is Max for all Axis
#define ENDSTOP_PULLUP_Z_MAX true //jim changed 11-19-16
#define min_software_endstop_z false //Jim
#define ENDSTOP_X_BACK_MOVE 8
#define ENDSTOP_Y_BACK_MOVE 8
#define ENDSTOP_Z_BACK_MOVE 8 //ENDSTOP BACKMOVE
#define ENDSTOP_X_BACK_ON_HOME 1 //Jim 11-10-2016 This setting helps control home final position.
#define ENDSTOP_Z_BACK_ON_HOME 1
