auto level mirrored
I am running the dev version on a ramps 1.4.
I use a inductive sensor as probe , the printer homes to zmax endstop , as is removed the z min endstop.
After doing a successful g32 s2, the printer compensates( i can feel the z axis move when moving x or y) but does it the wrong way around, the nozzle gets closer to the bed where the bed is higher and futher away from the bed where the bed is lower, in this way it amplifies the effect instead of compensating for it.
Did i do something wrong or is this a bug?
below is the auto level and z probe part of my config(i have set the probe points and probe offset in the eeprom, so the values for these in the config file are not the ones i use) :
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -48
#define Z_PROBE_Y_OFFSET -30
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 50
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 50
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 180
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
