EEPROM new parameter problem
Hi Repetier,
I define some new parameters for Scara Arm, but I have some strange problem in EEPROM.
for example arm length parameter:
Configuration.h Line 68: #define ARM_LENGTH 220
Communication.cpp Line 171: FSTRINGVALUE(Com::tArmLength,"Arm length (mm):")
Communication.h Line 164: FSTRINGVAR(tArmLength)
Printer.cpp Line 29: float Printer::ArmLength = ARM_LENGTH;
Printer.cpp Line 1328: ArmLength = ARM_LENGTH;
Printer.h Line 308: static float ArmLength;
EEPROM.cpp Line 76: Printer::ArmLength = ARM_LENGTH;
EEPROM.cpp Line 359: HAL::eprSetFloat(EPR_ARM_LENGTH,Printer::ArmLength);
EEPROM.cpp Line 576: Printer::ArmLength = HAL::eprGetFloat(EPR_ARM_LENGTH);
EEPROM.cpp Line 915: writeFloat(EPR_ARM_LENGTH, Com::tArmLength);
EEPROM.h Line 77: #define EPR_ARM_LENGTH 180
After long while, I finally found the problem is the firmware somehow doesn't read new parameters.
first time I defined EPR_ARM_LENGTH in EEPROM.h with 500, then I read EEPROM with repetier host, the result is I get "Extr.6" prefix before "Arm length (mm):" And I got value 0.
Then I modify with 700, I get "Extr.8" prefix and strange value 135
Last I modify with 180, the prefix is gone, but I get value 0.
How to fix this?
Tx
I put position 180 to 190 for new parameter, i also tried to reposition use 10 to 20, but the result is the same. All the value of new parameter is 0. Even if I manually add value from repetier host, it turn to 0 again after save.
