Extuder Heating problem
hello
my extruder start cooling down after reaching the desired temp
so , i can't start printing
thanks
  • #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 188.6
    #define EXT0_TEMPSENSOR_TYPE 9
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_DECOUPLE_TEST_PERIOD 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  2
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
  • Check the log if it detected a decoupling and simply turned it off for that reason. That you can adjust extruder settings to handle this better. Default values do not work on all extruders. Some swing more, others heat slower. So you might just need to adjust decoupling variables accoring to log message you get when it happens.
  • no error appears during heating or printing
    and temperature curve looks alright
    but the filament is stuck inside the hot end
    i try to clean it a lot of time but i always got the same problem
  • What is the highest temp you ever loaded? You may have burnt up the PTFE tube in the barrel of the hot end.
  • Clogged extruder is not automatic cooling down when target reached, so that problem is gone?
    There are many reasons for clogging, so hard to say what it was. Typical it is filament melting to high up blocking extrusion. Sometimes cheap filament has small garbage blocking nozzle. In any case clean up nozzle and check manually if you can push filament through the nozzle. This is also a good test to find the correct temperature as you feel how much force it takes.
  • i had clean it then try manual feeding
    it works alright with 400 ْ
    is that's alright ?
  • What are you extruding? Most extruders are defect at 400°C. PLA prints at 180-200°C. Our default maximum temperature is 275°C for that reason. Exceeding max. temperature turns extruder off.
  • Chinese one
    i know the pla prints at 180-200 but it does not melt with me at 200 - even 280
    • edited November 2016
      If doesn't melt even at 280 and you know it's not clogged, you probably have misconfigured the temp sensor.
      Also, does your PTFE tube go down all the way to the nozzle/heatblock? If so, it's not all metal and you should never exceed 240-245C.
      Past that temp, PTFE starts to deform and melt and not only will it clog, it'll also produce some nasty toxic fumes.
      Don't trust the Chinese hotends.
      P.S. After you try to extrude some filament, pull out the filament, does the end look like a plug? Do you have a fan on your hotend's heatsink?
    • thanks guys
      i got a new extruder and it works great
