Radds + 0.92.9 + MAX6675 Thermocouple
Hi everyone,
When trying to compile with the latest repetier online configuration tool (0.92.9 and DEV), I am
getting this error :
The error only append went I select MAX6675 as my temp
sensor, when switching back to my old 104GT-02 setting, everything works well.
Does this append to anyone else?
Arduino: 1.6.12 (Windows 10), Board: "Arduino Due (Programming Port)"
Build options changed, rebuilding all
sketch\Extruder.cpp: In function 'int16_t read_max6675(uint8_t, fast8_t)':
Extruder.cpp:2548: error: no matching function for call to 'HAL::spiReceive(int)'
         max6675_temp[idx] = HAL::spiReceive(0);
sketch\Extruder.cpp:2548:46: note: candidate is:
In file included from sketch\Repetier.h:567:0,
                 from sketch\Extruder.cpp:22:
sketch\HAL.h:820:20: note: static uint8_t HAL::spiReceive()
     static uint8_t spiReceive();
sketch\HAL.h:820:20: note:   candidate expects 0 arguments, 1 provided
Extruder.cpp:2550: error: no matching function for call to 'HAL::spiReceive(int)'
         max6675_temp[idx] |= HAL::spiReceive(0);
sketch\Extruder.cpp:2550:47: note: candidate is:
exit status 1
