Hotend Switching Problem
Hi, i switch between two hotends using the Fan2 Signal and a Tool change script in Slicer. However the tool change happens 2 seconds before the layer ends. I checked the G-Code which turned out to be correct. Now i'm questioning if something in the Firmware can lead to that issue. I'm using 1.0.0dev on a Radds 1.5 Board.
