Two controlable fans under RAMPS 1.4
Hi!
Is there any solution for two controllable fans under RAMPS 1.4?
To clarify, I use extruder cooler driven from D9. It turns on over 120 Celsius degrees, and turns off below. I like this behavior, because it's easier to heat up a bed. Now I would like add print cooling fan. What's interesting in web configuration tool I can choose from Fan pin and Fan 2 pin. Where is that mysterious Fan 2 pin? Is it software controllable (like D9) or 12V hot all the time?
Can I somehow use any of digital pins to control fan by M106 comand?
could you please show us the detail step by step how to setup the firmware for using this RepRap Ramps 1.4 Fan Extender? I google any step by step for Repetier firmware and found nothing.
I suppose you do this manually (on Notepad) after the firmware built by the Repetier-Firmware configuration tool, is that true?
Thank you!
It is using D6 and D11.
it works. Thanks!
Please clarify for the beginners. Is FAN_1, which I have running under Repetier Host command wired to Arduino Mega 2650 pin D9, intended for extruder cooling or print cooling? I think I have the Config set to turn this fan on when extruder temp exceeds 50 C, which the thermistor says is happening and PLA can be extruded. However, this fan only turns on under manual control from Repetier Host mouse control. Please explain.
Thank you,
