3d Laser Printer
Friends, I
build the powdered printer.
The laser
works fine only mode - Laser
But now it
is not included second extruder motor connector for leveling each layer of
powder.
The code
that you offered to me earlier for the control shaft through the extruder
motor. works fine mode only - FFF
T1
G92 E0
M302 S1;
allow cold extrusion
G1 E-100
F3000
G1 E0
F3000; back to origin
M302 S0
T0
Here the
firmware
Video:
mode fff
mode Laser
How can I run it all together at the same time and the laser engine and a second extruder connected to the shaft  ?
  • Your laser video is private, but you already said the solution - switch printing mode. Just uploaded new dev version that wait for end of moves when switching modes, which is important in your case. New code would be
    M451 ; FFF mode for shaft
    T1
    G92 E0
    M302 S1;
    G1 E-100
    F3000
    G1 E0
    M302 S0
    M452 ; Back to laser mode
    T0
    The problem is quite simple - in laser mode we interpret E moves as laser on during move and not as motor move. I guess you used that fact already to use simple slicer output.
  • edited October 2016
    I am grateful for the correct code! The mode switches and the device is moving correctly.
    I would like to clarify donations are accepted only through pay pal? Are there any alternative payment systems?
  • For simple donations yes, works best across all countries.
    If we speak about a better sum you can mail us for IBAN banking number, but that generally complicates bookkeeping.
