Add Choice in LCD Menu
I have two possibility :
- I use a triple head with mixing extruder (diamond hotend)
or
- I use three separate heads (two colors and one for support with PVA AquaSolve)
I would like to add this choice in the Extruder LCD menu :
Mixing Extruder (MIXING_EXTRUDER) on / off
Is't possible to change without flashing firmware and how to do?
Thanks for your help.
  • No, you can not switch in firmware. That flag is resolved at compile time to optimize speed. You could make it a variable and replace all MIXING_EXTRUDER tests with that and reprogram menu to change that variable. Maybe some other things also need tweaking as eeprom has a special extension for mixing case.
  • Ok, I suspected that a little.
    I'm not sure my knowledge allows me to change that way.
