M106 Commands being ignored when executed via Gcode
I can manually turn on M106 codes from both the Host and remote screen, But when I try to turn on the commands via gcode it ignores the commands. I even wrote a very small manual coding to see if it was the gcode but even my little segment gets ignored. I'm trying to use this as TTL commands for a laser. The laser does turn on, but it will not "fire" with gcode.
M107
M452
G28
M03
M106 S255
G1 X50
G1 Y50
G1 X1
G1 Y1
M106 S125
G1 X50 Y50
G1 X1
G1 X50 Y1
M107
G1 X1 Y1
Firmware settings
#define NUM_EXTRUDER 0
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN 58
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#undef Z_MIN_PIN
#define Z_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 100
#define YAXIS_STEPS_PER_MM 100
#define ZAXIS_STEPS_PER_MM 2287
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 0
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 1
#define LASER_PIN HEATER_2_PIN
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 1
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN HEATER_0_PIN
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define DEFAULT_PRINTER_MODE 2
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 675
#define Y_MAX_LENGTH 400
#define Z_MAX_LENGTH 200
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
#define FEATURE_WATCHDOG 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "MPCNC"
#define UI_PRINTER_COMPANY "Matt Robison"
#define UI_ANIMATION 0
#define UI_AUTORETURN_TO_MENU_AFTER 10000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define NUM_MOTOR_DRIVERS 0
A few things about my machine, I'm currently using D9 as the 12 V input for my laser, this controls the power on and acts as a safety feature to keep the laser from accidentally being fired. I'm trying to use a voltage modulated output (D58) to control the intensity of the laser (3.8w).
In a perfect world M106 S127 G1 X50 Y50 Should activate the laser at half power and lase to position. Below is more trial and error
Solution 1. I provided 12 V to the laser and kept the machine in CNC mode ( I also tried FFF) and tired to run the code. The only thing I got was movement, No indication of fan ( Laser Power) change in any mode. Failure
Solution 2 I tried changing pins once again from 58 to 44. Was able to verify voltage and change, that's when I noticed voltage transition was not solid it kept bouncing back to 5 V. So M106 S127 would show 2.5V but it would keep bouncing back to 5 V then back to 2.5 and so on under manual control, still no change.
Solution 3. With Extreme reluctance I installed Marlin on the machine just to verify if I could get solution 2 to work properly. I was able to get a solid 2.5 V at M106 S127. There was no voltage bouncing on the pin. The output of the laser was smooth and steady from M106 S1 all the way to M106 S255. I have not tried to see how this works in conjunction with X Y movements yet. First I have to re-learn how to work with Marlin, I've been using your firmware for 3 years and have come quite familiar with it.
The bottom line: 2 problems
Problem 1: I still can't get the machine to acknowledge the laser intensity (fan) commands by code I still have to manually change it. Mode (FFF,CNC,LAS) does not affect it.
Problem 2: The voltage output of D58 is not smooth so the laser intensity looks like Morris Code instead of smooth output.
I do not know the specifics but constant analog voltage is possible. The specifics of the install of the laser can be found here
http://www.vicious1.com/the-2-8-watt-100-laser/ The last page even has a picture of the output. It's 8 bit grey-scale raster output using variable output power not federate. You can watch a video of it in action here
I've really enjoyed using your software and firmware, I know you work very hard on it and take lots of pride, I can see it in the output. Thank you for you time and patience and entertaining the numerous idiots out there like me,
