Heater working sporadically. Is it a G-code problem?
Hi there.
I'm using a Printrbot Simple Metal that was bought some time back for our MakerSpace shared workshop. I've used Repetier-Host on the shared Mac Laptop with no problem for a month. They allowed me to take it home and I'm having problems.
I'm using Repetier-Host 1.0.6 with updated firmware (I'm 99% sure).
When I reset the Z-axis using the instructions on this site, everything was working great. I downloaded the virgin G-code for the fan shroud and printed it out with no problems. The problem begins when I try to print my own models.
When I first tried to print my own models that worked fine before the computer and location change, they weren't printing well, but at least they printed. By not printing well, I mean there seemed to be gaps in between layers that there weren't with the shroud. Doing some digging, I went into Slicer, changed the layer height to .15 mm, changed the vertical shells to 5 from 2, and horizontal shells to 5/5.
For some reason, the exturder will not by any means heat up when I try to print my own models, but will print out when I use the G-code.
HELP!
I went back to the factory Slicer settings, but that didn't help.
Any thoughts? I have to return the printer tomorrow
Thanks in advance.
HELP!
