Z probe doesn't work after z home max
hi
i have a strange problem, if i dont home the z axis from my printer the z probing works pretty fine but after z max home the z probe wan't work, the printer ignired the z probe offset and just drive the z axis too z min but with out trigger so the nozzle hits the bed.
In the repetier host G33 is an unknown command(G32 still works), i think i've this issue cause z-probe support is not compiled.
But my configuration string is very old and dont match with my used config.h so i cant upload my config into the online configurator to enable the support without losing my settings
If i send the command G32 the printer makes 3 test executions on 3 points, but with out correction.
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PIN 63
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET -56
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 1
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 5
#define Z_PROBE_Y1 5
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 5
#define Z_PROBE_X3 5
#define Z_PROBE_Y3 130
#define BED_LEVELING_METHOD 0
#define BED_CORRECTION_METHOD 1
#define BED_MOTOR_1_X 266.5
#define BED_MOTOR_1_Y 97
#define BED_MOTOR_2_X -91.5
#define BED_MOTOR_2_Y -18
#define BED_MOTOR_3_X 288.5
#define BED_MOTOR_3_Y -18
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
here you can see the log from the host app
