Z Homing Question
I have rebuilt a 1st gen cube 3d printer to use more conventional hardware and have 1 thing left that is a bit of a annoyance but not sure how to go about fixing this.
I am guessing the behavior for homing a axis is move X steps then start going back till you hit a end stop.
My problem is moving X steps does not get the axis past the end stop. It takes me homing it three times before it finds a proper home.
Is there a way to adjust the Z axis steps taken before it steps back or some other suggestion someone can make that will fix this?
I have a printer 3d cube 1st generation.
you know how I can print it using repetier-host?
I have uploaded firmware 2.08 and joined in with the wifi, but I can't print.
I appear to me often mistake "communication timeout - reset send buffer block"
can you help me?
