[Mini Kossel Delta] G33 starts in opposite direction to G32/Bed Height Map routine?
Hey guys, I just changed to repetier firmware from marlin.   I followed the video instruction from this link to calibrate my delta printer (https://www.repetier.com/documentation/repetier-firmware/z-probing/).
I am curious why the starting point of G33 is opposite to G32 or "Bed Height Map".   G32/Bed Height Map starts at lower left hand corner under X-tower, but G33 starts at upper left hand corner beside x-tower.
Is there something wrong in my setting?
[Bed Height Map Setting]
x-min -20
y-min -50
x-max 70
y-max 75
x-point 4
y-point 7
[configuration.h]
#define DISTORTION_CORRECTION_POINTS 7
#define DISTORTION_CORRECTION_R 50
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 0
#define DISTORTION_XMAX 50
#define DISTORTION_YMAX 50
[EEPROM Setting]
Max printable radius: 80mm
Z-probe offset x : 31mm
Z-probe offset y : 31mm
Z-probe x1 : -20
Z-probe y1 : -50
Z-probe x2 : 65
Z-probe y2 : -30
Z-probe x3 : --65
Z-probe y3 : 65
  • G32 and G33 just are complete independent each defining a separate region for testing, so this can happen it is no error.
