Thermistors decouple
Ok I dont know what to do at this point. I have replaced the Adruino Mega, the RAMP1.4 board and the PSU to a very clean one for ham radios (very low ripple 12v).
If I heat both extruders they decouple and the temps drop. in frustration I set the EXT0 and EXT1 DECOUPLE_TEST_PERIOD to 300000 and actually watched the temps rise get up to around 100 C and then just start falling. So they indeed decoupled.
If I heat each extruder individually it heats and holds its temperature (same with the bed). So the Thermistors are working
I watched the current output on the power supply and it is below 16 amps (total 5amp circuit and 11amp circuit). Typically bouncing between 3 and 10amps. If I heat just the two extruders the current draw is 7 amps
I have spent countless hours working through all the settings. I have everything mechanical worked out. I just cant get past this one and dont know where to look.
Help Please.
