Z-probe home position problem
I have some problem with autoleveling. My hardware configuration is:
- Z-probe: Capacitive proximity sensor LJC18A3-B-Z/BX (signal is connect via voltage divider to pin 4),
- Electronics: RAMPS 1.4.
- Firmware: 1.0.0 devel
- Endstop: only mechanical on X and Y (no endstop on Z)
Triggering probe works great - if heatbed is detect then Z-probe state changes to H (testing by "G31").
If z-probe not triggered (z-probe is for example 8mm above the heatbed) command "G32 S2" is performed correctly.
But if z-probe is triggered (z-probe is near heatbed) command "G32 S2" or "G30" goes Z axis up (10 mm) and then show error:
Error:z-probe triggered before starting probing.
Error:Probing had returned errors - autoleveling canceled.
Is there a way to start autoleveling from home position when probe is triggered?
Thank you for advice
