Delta Homing trouble after endstop calibration
Just after endstop calibration, by entering G132 S1: The sliders go to the endstops, go down by 20mm (as setup in the firmware for safety reason), and then go up so fast that it's like the stepper motors loose some steps. They only go up for few millimeters upward, but I cannot trust the real coordinates after that. The 92.8 didn't have this kinf of problem...
Any idea?
Thanks!
case 132:
and uncomment the home command at the end. Then it should only leave the 5mm down and it should be easier to spot when exactly the problem occurs. Of course you then need to home manually.
