How do you compensate for Concave / Convex like Marlin FW?
Calibrating my G2S Pro is driving me insane. I really want to use Repetier, but I'll give it one last go before I go back to Marlin
I can get my hotend calibrated quite well, however I find that when my centre is perfect, the edges are raised by about 1-2mm
When I get the edges perfect, the centre is then too low and crashes into the bed.
I've tried adjusting the Z Height and the problem just moves around.
In Marlin, I could adjust the DELTA_RADIUS to compensate for this, however I can't seem to find the right value to adjust for this in Repetier.
Does PRINTER_RADIUS do this?
Or is it ROD_RADIUS?
I've seen so many conflicting views on what does what.
My printer is a G2S Pro from Geeetech. Thanks in advance.
