Filament out pause
"Put the microswitch on the UI_ACTION_PAUSE action"
  • Put the microswitch on the UI_ACTION_PAUSE action
    Can someone please explain how to implement the above action. What pins do I connect the microswitch too? I use ramps 1.4. What is UI_ACTION_PAUSE and how do I connect to it??? I use Repetier Host and I don't use an LCD screen or sd card. I want the microswitch to pause the print but still be able to use the xyz axis and extruder and then after that resume the print.
  • Should be quite simple. Add this in manual tab and adjust pin to the one you used. Pin must connect like this: gnd->switch->pin
    #define USER_KEY1_PIN     60      // set to pin you used for switch
    #define USER_KEY1_ACTION  UI_ACTION_PAUSE
