Copying file to Sd card Da Vinci 1.0.a Repetier .92
So, I have the option to copy across etc and nothing seems to work.
The file copies but when I check the printer the file isn't listed on the card.
By default it is named .gcde and I have tried renaming to .gcode which is the same extension the demo files have but still no luck.
I have check the binary to allow for repetier, i have even manually copied the cgode across and still no luck.
Any ideas where I'm going wrong?
Also running repetier 0.92 on a da vinci 1.0a
I can print fine through repetier host (v2.3.2) I can also copy the file too the sd card but it does not show up in the printer.
I have one file showing up in the printer (one that i made years ago) and am able to print this from the printer. When i open this file on my laptop it seems to be encrypted? The file extension is .gcode so i'd say it is a normal gcode file.
am i missing something here?
