Height Reduction Rostock
HI everyone,
I have an issue that I believe is a firmware problem, but looking for advice to narrow it down. I have modified my Rostock Max v1 for high accuracy using 1/32 step rate with Arduino Due/RAMPS-FD controller setup. I have the bed level to within 0.05mm with a nozzle height of 0.2mm. When I print my first layer, the perimeter is perfect, but when it starts the infill (45 Degree Lines) the nozzle will slowly get closer and closer to the print bed until it either tears the tape or stop laying material down, but only on the right side of the print. The Pic explains it better than I can. See Pic I have also noticed that the head will start to pull away from the perimeter at the same time. Visible down the right side of the pic. It appears to be a cumulative rounding error (adding/subtracting rounded numbers together) just from my experience from C programming which may or may not be repairable.
Any suggestions welcome.
