Delta Calibration Assistance
I have read many pages on the www, worked to correct tower errors, worked to ensure everything is as straight as possible.
Before moving to diamond head, this printer has printed many objects OK. Moved to Repetier firmware.
I have calibrated the printhead so there is perfect pressure on the printing plate and even on all three axis.
When I send the command to go to 0,0,0 There is about a 3mm difference between the center of the print bed and the outside towers.
I know the bed is flat, at least flat enough where a 3mm dip would be noticeable. I have used squares, levels, and measurements, the bed is flat.
Why does the hotend sit 3mm higher in the middle than the edges? More important, how do I fix this?
Distortion?
#define DISTORTION_PERMANENT 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
Also have baby stepping enabled mupltiplcator 1
and #define ALLOW_QUADSTEPPING 1
EEPROM,
Corr diagonal A, B, C, set at 0
Delta Rod Radius A, B, C set at 0
Tower endstop Offsets A,B,C set at 0
Where should I look to understand what is hapenning here?
NOTE: Always readjust/check z height after doing this because as middle goes down, out edges will go up changing starting print height. This can be found and changed in eeprom. Start wilh a little change in case I have it backwards.
