The X & Y size are different with Z coordinate for 1cm cube (Delta 3D printer)
I'm building the delta 3D printer, about machine size, i use the ruler to measure all our need.
it includes below items.
1. Z length (Z_MAX_LENGTH)
2. Diagonal rod length(DELTA_DIAGONAL_ROD)
3.Horizontal radius when centered(ROD_RADIUS)
4. Max. horizontal radius(DELTA_MAX_RADIUS)
When i tried to print 1'st object (it's 1cm cube), the Z-high is correct (Z high almost equal to 1 cm) , but the long in X and Y equal to 0.7 cm
And i don't know what's error,
If you have any experience about this issue, please help me to provide some direction to solve it.
Thx!!
  • If z height works your steps per mm are correct. That is also easy to measure as 1cm up down moves all gliders exactly 1cm.
    My guess is that your length are not measured correctly. Diagonal rot length is from rotation center to rotation center. Horizontal radius is NOT measured from extruder center to outer rotation axis, it is again from rotation center to rotation center, just only the horizontal part.
    See
    on how to calibrate for correct dimensions.
  • edited July 2016
    Yep, your Diagonal Rod length is incorrect.
