Z probe not Working
Hello, I'm using Repetier 1.0 DEV, and i'm having a problem with Z probe (Delta printer)
Z probe connected to pin 18 of RAMPS (Z MIN), and seems to be working :
> 13:58:33: N16 G31 *12
< 13:58:33: Z-probe state:L (when not activating the sensor)
> 13:58:37: N21 G31 *8
< 13:58:37: Z-probe state:H (when activating the sensor by hand)
When using G3S S2, the probe does not work (the head crashes in the bed
Here is my config :
#define Z_PROBE_Z_OFFSET 1.1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PIN 18
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 1
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 15
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 1.1
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -120
#define Z_PROBE_Y1 -80
#define Z_PROBE_X2 120
#define Z_PROBE_Y2 -80
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 140
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
hopes this helps a bit
