Extruder going too high while probing
Mendel90 with capacitive sensor and Repetier V92.9 from today. Z leveling set up with 3 point measure and 3x measuring at every point. Bed travel distance set to 5mm.
Let's say my extruder is at Z=60 after starting up the printer. I issue (with Octoprint) a G28 x y (printer homes X and Y. Then I issue G32 S2. The extruder goes to the right XY position for the first probe, goes down until probe light goes on. Then, my problem, the extruder goes up to the original height, goes down to measure, goes up to original position and so on. I understand that it should only go up 5mms to measure again, right?
What's wrong?
Cheers, Ralf
What's wrong?
Cheers, Ralf
G28
G1 Z30
G32 S2
