Reprap Prusa I3 Z axis won't move down
Hi mates!
I'm having problems with the Z axis because won't move down just up, I'm trying everything, changing the firmware code, changing the motor trim
I'm was trying to set the end limits of the Z axis with Repetier software sending manually codes but when I hit the negative button of the manual control the Z axis won't move down just up and also in the cod lines appear this : gl_Paint-1.OpenGL error:InvalidValue every time I hit the negative button, but when I hit the positive the axis moves up normally
Hope some of you can help me with this
Thaks!
Thaks!
