Error Z Probe Bed Height
My name is Mariano, I own a P3Steel that prints correctly using RAMPS 1.4 Repetier Firmware V 0.92 and Repetier Host in Lubuntu.
I am making some changes to use my printer as a PCB CNC Mill. I manage to make Z Endstop work as a conductivity and works great.
My problem is that usin Bed Height Map function or G32 code in manual control it tells me:
Error:z-probe triggered before starting probing.
Strange thing is that if i use G30 code this error does not appear.
Any solution???
This is my log:
22:24:43.291 : OpenGL version:2.1.2 NVIDIA 304.131
22:24:43.292 : OpenGL extensions:GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
22:24:43.293 : OpenGL renderer:GeForce 6150/integrated/SSE2
22:24:43.293 : Using fast VBOs for rendering is possible
22:24:54.001 : Printer reset detected - initalizing
22:24:54.003 : start
22:24:54.018 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
22:24:54.019 : Free RAM:5163
22:24:54.037 : SelectExtruder:0
22:24:54.188 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
22:24:54.190 : Printed filament:83.92m Printing time:0 days 21 hours 45 min
22:24:54.190 : PrinterMode:FFF
22:24:54.211 : X:0.00 Y:0.00 Z:0.000 E:0.0000
22:24:54.211 : DebugLevel:6
22:24:54.212 : SelectExtruder:0
22:24:54.213 : DebugLevel:6
22:24:54.213 : SelectExtruder:0
22:25:10.977 : X:0.00 Y:0.00 Z:0.000 E:0.0000
22:25:33.936 : Z-probe:0.50 X:0.00 Y:0.00
22:25:34.686 : Z-probe:0.47 X:11.11 Y:0.00
22:25:35.395 : Z-probe:0.42 X:22.22 Y:0.00
22:25:36.067 : Z-probe:0.40 X:33.33 Y:0.00
22:25:36.739 : Z-probe:0.42 X:44.44 Y:0.00
22:25:37.414 : Z-probe:0.41 X:55.56 Y:0.00
22:25:38.102 : Z-probe:0.44 X:66.68 Y:0.00
22:25:38.790 : Z-probe:0.40 X:77.77 Y:0.00
22:25:39.446 : Z-probe:0.38 X:88.89 Y:0.00
22:25:40.211 : Z-probe:0.63 X:100.00 Y:0.00
22:25:42.018 : Z-probe:0.22 X:0.00 Y:11.11
22:25:42.488 : Z-probe:0.19 X:11.11 Y:11.11
22:25:42.915 : Z-probe:0.13 X:22.22 Y:11.11
22:25:43.284 : Z-probe:0.09 X:33.33 Y:11.11
22:25:43.632 : Z-probe:0.09 X:44.44 Y:11.11
22:25:43.985 : Z-probe:0.09 X:55.56 Y:11.11
22:25:44.356 : Z-probe:0.13 X:66.68 Y:11.11
22:25:44.775 : Z-probe:0.18 X:77.77 Y:11.11
22:25:45.135 : Z-probe:0.02 X:88.89 Y:11.11
22:25:45.466 : Z-probe:0.10 X:100.00 Y:11.11
22:25:47.008 : Z-probe:0.21 X:0.00 Y:22.22
22:25:47.454 : Z-probe:0.16 X:11.11 Y:22.22
22:25:47.847 : Z-probe:0.10 X:22.22 Y:22.22
22:25:48.182 : Z-probe:0.05 X:33.33 Y:22.22
22:25:48.455 : Error:z-probe triggered before starting probing.
22:25:53.526 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.529 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.553 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.554 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.556 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.573 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.582 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.595 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.605 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.614 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.627 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.636 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.647 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.660 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.667 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.679 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.688 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.701 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.712 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.720 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.733 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.742 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.755 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.765 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.774 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.786 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.795 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.808 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.815 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.828 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.839 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.852 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.859 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.869 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.880 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.893 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.900 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.913 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.922 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.933 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.946 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.955 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.966 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.975 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.988 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:53.999 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.008 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.019 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.028 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.039 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.053 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.062 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.073 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.081 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.094 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.103 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.114 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.127 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.134 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.147 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.156 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.167 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.180 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.189 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.200 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.208 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.222 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.233 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.242 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.253 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.262 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.275 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.286 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.295 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.311 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.316 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.327 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.340 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.347 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.360 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.369 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.380 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.389 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.401 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.414 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.421 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.434 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.441 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.454 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.467 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.474 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.487 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.496 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.507 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.521 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.527 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.541 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.547 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.561 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.574 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.581 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.594 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.602 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.613 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.627 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.633 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.646 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.655 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.666 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.675 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.687 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.700 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.708 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.721 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.728 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.741 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.752 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.761 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.774 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.781 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.794 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.807 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.814 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.828 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.835 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.846 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.859 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.868 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.879 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.888 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.901 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.908 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.922 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.933 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.941 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.954 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.963 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.974 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.987 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:54.994 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.007 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.014 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.028 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.039 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.048 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.061 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.068 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.081 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:55.092 : fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:25:58.062 : info:Continue from fatal state
  • When you start probing you must be above the printbed/pcb! That is what the error says and since you did not say it was wrong the solution is just to move a bit higher before probing starts.
  • Great, thanks
    It worked if i start higher.
    Now my question is if the Bed Prove results can modify GCode to take PCB height variation on Z axis? I mean to modify GCode copying this variations.
    Thanks again
    Mariano
