Delta: servo motors keep moving up and down in circles
I'm building a Delta Robot style printer using a Rumba board with the XYZ axis connected to the towers. Using the Repetier latest (and dev) firmware, I'm not able to get control of the printer. At start of the firmware all the arms are being pulled and down slowly one by one. Then after 1-2 seconds this process start again but faster and never stops.
I'm suspecting something with the end stops although the look to be setup correctly. they are micron switches in the top in normal state connected by the + lead to the signal, switched on it's the - lead that connects to the signal.
My end stop config is:
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
  • Use M119 to verify endstop status, then you know if they are set correctly.
    Motors should not run at startup, except if oyu have home on power up enabled.
    Firmware only works with steppe rmotors so I hope your servo motors are stepper motors:-)
