Z Axis Homes and Moves Down, But Won't Move Up Under Manual Control
edited May 2016 in Motor Control
I have a Prusa Mendel i2 that was working great under Sprinter/Pronterface. I uploaded Repetier Firmware to the Mega 2560. My Z axis properly moves to Home when the button is pushed in manual control. It will also move down when the down arrow is pushed. The problem is that it won't move at all when the up button is pushed.
Research suggests it has something to do with the endstops. Here is the current part of the Configuration.h file:
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 120
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
M119 Command returns: endstops hit: x_min:L y_min:L z_min:H  z_max:L
Any suggestions?
I'm running Repetier Host 1.6.1 on Win 8.1. RAMPS 1.4
Thanks!
  • Do you really have z min and z max endstops?
    says you have max endstop. I fthat gets high signal it won't go up.
  • Thanks. No, I don't have a z max endstop. I changed the setting to #define MAX_HARDWARE_ENDSTOP_Z false and uploaded it to the board. It worked until I disconnected. After reconnecting it stopped working. I've also noticed that my bed has disappeared from manual control and only reappears if I disconnect and restart Repetier Host.
    M119 Command now returns: endstops hit: x_min:L y_min:L z_min:H
  • When connected bed is only visible if M105 responses show a bed temperature, so it has autodetect of bed.
    With z min high you should be able to move up as long as you are below z length, check eeprom.
  • Please be more specific about the eeprom.
  • z length parameter stored in eeprom.
    Our host/server have an eeprom editor to check/change these parameters.
