"X, Y, Z axis stepper motor" I have a Delta and this got very confusing, should all of them have same values? I did selected "rostock, kossel" But the Z axis has different values if you look at X, Y
The configuration tool output is not correct for the delta - v.0.92.9 Some where this broke going from 0.92 to 0.92.9. I think.
I had to manually edit to make the Z values the same as the XY on axis stepper motion and also two other areas which listed amounts the axis move. I think it was homing bounce and position.
