Jitter on short segments by high res stl files/curves/arcs
Hello!
Know anyone the problem thet by short segments the printhead are jittering? It looks like the printer drives any small segment with initial jerk moves. I have no more idea
i use marlin 4due bevore and there was no problem by interpreting arcs and move smothly. I dont want to change back and i think thers a way tu config out the problem...
I have tryd to set delta segments to 600 and segments per line to 100 etc but nothing helps.
My setup: core xy,radds, arduino due, tmc2100, hall e endstops.
Thanks for any answer
Thanks for your quick answer! Yes of curse, i set max delta segments to 600. and you say i can set this on my core xy to 10? ore lines per secound?. My buffer is set to 24 lines. Is will set this to 32? I think it is better i post my config.h...
