Split Object is grayed out in v1.6.0
Split Object is grayed out in v1.6.0.
Do I need a different version to do that? Thanks
  • It is not split object, it is view split. It is only selectable once a object is selected.
    No, I want to "Split Object", because the object is too tall.
    I've linked a picture, it's grayed out.
  • OK, I thought about the other function.
    This split is for stls conatining of several objects e.g. a set of chess figures. These can be split with that function. It can not split a single shell into subcells. Use Meshmixer for this.
    Great, thank you so much!!
