Marlin to Repetier Firmware convert
I am very new to RepRap machines and it's very hard to me to set them up. i'v tried the Repetier config tool but some of the config options i see, i have no clue how to find or measure.
So is there someone who can check these two config files and maybe make a Repetier Firmware out of it and upload somewhere that works for me and everyone else who bought this setup?
Marlin Firmware (Default config from factory, except "MANUAL_Z_HOME_POS 283.11")
http://s000.tinyupload.com/index.php?file_id=90721608662915188420
Repetier, Almost done Config.h
http://s000.tinyupload.com/index.php?file_id=09043112183759982257
it's this printer
http://www.aliexpress.com/item/LCD-display-diy-delta-3d-printer-kit/32325215996.html
And it has 4 Endstops, one on the effector for Auto leveling and that's what i'm after in the Repetier firmware!
  • Trin,
    Have you figured out your printer?
  • Looks like both are Repetier files. Read line 33 - 35. I compared the files in Notepad++ and noticed you changed the board type and adjusted a few length parameters.plus turned off distortion correction and changed feature controller.
    Does a G31 return the correct responses activated/unactivated? Could be the pin assigned, pullup, on_high settings. There is a good tutorial on bed levelling on the Repetier.com  site.
    Just saw this post.
