can repetier echo the gcode line number
currently the information window in Repetier echoes the layer that is being printed. Can it echo the actual gcode line number? The reason I ask is that if I have an air print issue and I catch it earlier enough I might be able to determine where in the code it failed. I could then edit the gcode to restart the print at the location where I believe it to have failed. If there is a better way I would sure like to hear about it.
Air Printing was a "big" problem when I first started out but now I seems to have a handle on it. But I ask anyway.
