Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
General
are tb68650 stepper drivers supported?
boelle
May 2016
in
General
are these drivers supported with their special timing requirements?
boelle
May 2016
i meant TB6560
Repetier
May 2016
You can set STEPPER_HIGH_DELAY and double step delay, so you can adjust to your stepper needs as long as they need enable/dir/step signal. In config tool you need to enable advanced mode to see the timing fields.
boelle
May 2016
if i find the right values can my board be added as a selection in the drop down? if its not allready there
Repetier
May 2016
Is this a sold board?
Boards do not contain timing data, so the extra delays are not set by selecting the board.
boelle
May 2016
of course its a sold one, but if the timing data are not set by selecting the board it does not matter
Repetier
May 2016
On esolution is to offer the config tool Configuration.h as a starting point. That would have set the timings correctly for users to start.
boelle
May 2016
good point :-D
Sign In
or
Register
to comment.
