Adjusting distance from bed
I have just been given a delta printer and I am trying to set up some easy scripts which can be used by anyone to setup the printer.
The process of setting up:
  1. Home
  2. Calibrate (auto mode)
  3. Adjust Z for bed coating
  4. more settings....
I am stuck on number 3, it has to be done manually but I want to find the G code command to do it. The printer has options for buildtak, painters tape, kapton tape and pritt stick. I believe it just adds an offset but im not sure.
I use M114 to get the position when at home for the z axis, then I change the surface to buildtak and send M114 again at the home position and theres a 0.4mm diffrence in the 2 readings (thickness of buildtak).
One method I thought of was to go to a known position, say 100.4 and set the axis to 100. BUT if the code is run twice it would add up creating a 0.8mm offset. When it is set up manually, if the build surface offset has already been entered it doesnt modify it again.
How would I change the build surface height in G code?
  • In eeprom there is a parameter for this. Bed coating I think. You can also change it on the printer lcd.
    Anyhow enable command logging, open eeprom editor in host/server and change the value. You will see a M206 command appear. That changes the bed coating in eeprom. Remember it (without N and * part) and replace the value with the coating you want. You need to home afterwards to have it change the height.
