Core xy - Capacitive Sensor for Autoleveling and Home z issue
Hi there,
I recently upgraded my Sparkcube 1.1 (Core xy) with an capacitive sensor and Autoleveling and got rid of the mechanical switch. Right now I´m using the capative sensor on Digital PIN 63 for both, Homing the z-axis and Autoleveling / Z- Probe (Repetier 0.92.9). My printer ist running for a couple of days now and Homing x, y and z-axis and Autoleveling ist working fine.
Right now I only have one issue: If I home x, y and z- axis and start G32 S2 from home position the hotend- carriage crashes into my home position (x = 200, y= 200, z= 0) with a loud vibrating noise. The problem only occurs at G32. Starting for e.g. print from home position works just perfect. In order to avoid the crash I have to move the carriage in the middle of the printing bed and G32 S2 works well again.
Any ideas on how to solve this issue? Thanks a lot for your help!
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PIN 63
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
  • The only thing I figured out is that homing to Z_min and starting G32 S2 is critical in general and should be avoided. Why is that? How can I solve this issue?  Thanks for your feedback!!
