COREXY - Auto level & Z-homing
I have built a SPARKCUBE XL with ramps1.4. i set the extruder 1 to the third motor..
im using the http://www.repetier.com/firmware/v092/ for configure the firmware...
So, i have set the option Mirror motor signals to other stepper driver (FEATURE_TWO_ZSTEPPER)) and then in "MIRROR STEPPER SOCKET" and choose the "Extruder 1"..
In the Endstops i have the follwing settings :
The X and the Y line to the Home properly ... this is not the case with Z....
I have an inductive sensor, connected to the Z-min-Endstop.
Problems:
a) When I run the G28 Z0, the Z axis moves extremely fast, but when I give the instructions for the Z move 10mm it moves at normal speed.
b) How can I set the Z0 for this to be at the top, when you activate the sensor.
am i configuring something wrong ?
Best Regards
Bruno
