G-code support
-https://github.com/MagoKimbra/MarlinKimbra  has implemented new gcode command, G60 and G61.
The first one store the "actual position", while the second correspond to G1 X[stored X position] Y[stored Y position] Z[stored Z position].
Will you be willing to add this to the Repetier firmware. Will make live easy with toolchange or colour change where you want to purge colours and return to the last position to continue print
  • That is already implemented. Soo repetier.ino for implemented commands and check I think it was M400/M401 for memory position and go to memory position.
  • Thank you very much !!!!!
