How do you change the Effector Radius
I'm designing a new effector, which as it happens needs to have a larger radius (35mm instead of the standard 20mm).
My intuition tells me that I should also change a setting in the firmware, as the general geometry will be changed, but I can't find any documentation about this.
Does anybody have any idea on what variable needs to be changed to accommodate the new effector radius?
Thank you so much,
Eros
  • It is included in horzontal radius which is distance between diagonal rotating points when centered. So if you go from 20mmradius to 35mm radius the horiz. radius should shrink 15mm.
