Issue with Y-axis speed and extruder 0.92.9 DELTA RADDS 1.5 RAPS128 DUE
Hi all,
I recently upgraded my Delta printer to RADDS 1.5, RAPS128 and Arduino DUE to improve movement and print quality.
My issue is, that the Y-axis is much faster than X- and Z-axis. Also the extruder (E1 on RADDS) doesn't work.
I got 0.9° stepper motors for all drive axis (X,Y,Z) and 1.8° for extruder (E1). Radds board is configured at 128 steps for drive and 32 steps for extruder. RAPS128 are at 1.92V and decay at default.
I tried to switch RAPS on the board but the problem persists at Y-axis.
I also tried 0.92.8 and 0.91, problem is still present. M502 and M500 didn't help either.
I think the hardware is working fine and reckon it's a wrong setting in the firmware.
I can't figure out any solution, so any help is highly appreciated!
My configuration.h (0.92.9)
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 1280
#define YAXIS_STEPS_PER_MM 1280
#define ZAXIS_STEPS_PER_MM 1280
#define EXT0_STEPS_PER_MM 1740
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 70
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 302
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_UPDATE_FREQUENCY 12
#define DISTORTION_END_HEIGHT 2
#define DISTORTION_EXTRAPOLATE_CORNERS 1
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define DELTA_SEGMENTS_PER_SECOND_PRINT 600 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 400 // Less accurate setting for other moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 407 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define END_EFFECTOR_HORIZONTAL_OFFSET 35
#define CARRIAGE_HORIZONTAL_OFFSET 27.5
#define DELTA_MAX_RADIUS 150
#define ROD_RADIUS 245.5
#define PRINTER_RADIUS 245.5
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 0
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 200
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 300
#define MAX_FEEDRATE_Y 300
#define MAX_FEEDRATE_Z 300
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 50
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 50
#define STEP_DOUBLER_FREQUENCY 90000
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1500
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1500
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1500
#define MAX_JERK 25
#define MAX_ZJERK 25
#define PRINTLINE_CACHE_SIZE 32
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 1
#define FEATURE_WATCHDOG 1
