Homing problem with delta printer
ME1ME1
edited April 2016 in Motor Control
Printer is a CZ-1 2.0 Rostock delta kind of printer.
I am new to the 3D printer field.
In principle all works (coolers, steppers, MAX endstoppers according to M119 status)
When I press the all home button in repetier 0.92.4 windows version the axis move so that the hotend carrier crashes to the wall between Z and X axis.
Shouldn't it move all 3 steppers up to the endstoppers at the same time?
If I switch off the printer, slowly move all 3 steppers to approx the same height, switch on again I can go up all 3 steppers to the Z direction using manual control, only X stepper stops as soon as X shows minus values.
What maybe wrong in this case?
Is the
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
[ Configuration.h that I got from the manufacturer ] wrong?
  • Deltas home all to max and at the beginning all motors move the same time until endstop is triggeren which stops the according axis. Current firmware release even has a test if endstop triggering/untriggering worked as expected. You would see this in host log. So what I guess is that the endstops trigger early, maybe trough crosstalk or wrong configuration. Make sure motor cables/endstop cables are twisted to reduce crosstalk. Check with M119 if all are low when below endstop so you know at least that start signal is correct.
  • ME1ME1
    edited July 2016
    After checking and some good help of the guys at robotrebels.org the
    culprit was a broken soldering to the Z endstopper and a slipping wheel
    on the Y axis. Now homing works and I was already able to print a few
    standard 20mm cubes for calibrating:
  • Ah yes and the
    was also wrong.
    This was also necessary to make it work:
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
