X motor losing steps
I recently upgraded from RAMPS/Mega to RADDS/Due. I'm using Raps128 with 32/1 micro stepping, as I did before.
But now I'm encountering some issues with lost steps, as seen in the picturere.
I've uploaded the latest firmware 0.92.8, but might have have missed something?
Any suggestions on how to approach, would be awesome.
Thank you.
Best regards
Christian
Thank you.
Best regards
Christian
My jerk/acc are default values, haven't altered them. The check endstops option is already disabled. Could it be a noise issue, regarding the DUE's 3v3 logic being more sensitive to EMF from the PSU, than the old Mega?
I suppose it could also be a slicing issue?
you get this issue with too low current or otherwise with overheated motor (overheated by too high current).
if current setting is correct , try to swap the stepper driver from x to y vice versa , if the issue moves to y axis it´s located at the driver
Thanks for the feedback.
