Nozzle and Plate Heaters Will Not Come On
Neither the hot head nor plate heaters will turn on, and head temperature
readout indicates 460-500 Deg C, although everything is actually cold.
Plate temp reads correctly, but the plate heat will not come on either. I
pulled the thermistor leads from the RAMPS board, and checked
resistance compared to a new thermistor, and the thermistor reads
correct compared to others at room temp.
This is a Folgertech
Kossel 2020 (rev a) with Ardino 2560 and RAMPS Shield. Repetier Host
V1.6.1 I have also checked all of the power lead terminals for
tightness.
The machine itself moves normally. I alao the Emergency Stop, and rebooted everything, including my Laptop, with no success.
Has anyone had a similar problem? Unless someone
has some troubleshooting things I can try, I suppose the next step is to
order a new RAMPS board?
tightness.
