Trouble with endstop configuration
I'm currently doing the first tests, and I'm faced to a small issue : the endstop detection is not working.
On the hardware side, I checked that the Y-axis endstop is working, and is connected on the proper Y-axis.
The M119 command provides the following result:
08:38:53.909 : N36 M119*31
08:38:53.924 : ok 36
08:38:53.924 : endstops hit: x_min:L y_min:H z_min:L
Unfortunately, when Y-axis is moving, and the endstop pushed, the axis is still moving...
I guess it's something not properly set within the configuration file.
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
Any ideas ?
Samuel
  • I found my issue : I did invert the motor X and motor Y connection.
    Hope it can help someone else...
         Samuel
