Repetier Host won't load
I am running Windows 7, when I attempt to start Reptetier, it won't load. I get an error stating that "RepetierHost has stopped working". I have uninstalled and reinstalled a couple of times with no success. I also restarted in SafeMode, I was able to get the program to run at that point without issue.
Thank you
I have the same laptop as a co-worker who had no issues. I am assuming it is a software issue, but I haven't yet figured out what the problem might be. I have tried to uninstall/disable a few possibilities but have not had any luck. Any suggestions?
Thank you
