Temperautre Defective at -50.88oC
Hi All
I have a slight issue with trying to sense temperature and was wondering if anyone can please help.
I have a J Head with temp sensor in, this is an epocs sensor.
Resistance reading: around 100k
V reading out the T pins: around 4.5 to 5
When i heat up the temp sensor it changes the resistance also the voltage from the pins. That should mean that everything is working well, however on my software i am getting a reading of -50.88 degrees C
Please may someone help me fix this issue.
I have an Arduino mega with Ramps 1.4 using repetier firmware and host
Kind Regards
Josh
Kind Regards
Josh
OK well i have tried all of the above, and all i get is the minimum temp i set the thermoster to have, I have tried doing a generic table, working out my beta and testing, still not working. my thermistor definitely works. Is there something stupid that I am doing?
I have tried using analogue 3 off to the side of the board too which also does not work.
I must be doing something really wrong nobody else seems to get this same problem.
It would be brilliant if someone could take a look at my code and check to see what I am doing wrong.
Any help would be much appreciated. This the last hurdle to getting my printer extruding as everything else works.
