Melzi + Z Probe (Another Auto Level Question)
New repetier user here, coming from Marlin. I came because of the support for the 5 key ADC panel and the config tool. I had auto level working on my Marlin machine and I want to make sure I have it all set up correctly for repetier.
From my understanding its not good practice to use the z probe as a z end stop but seeing as I have a Melzi board i don't have any other ports. With marlin It would check for home in the middle then do the grid to check for auto level.
What do I need to do in Repeteir to have the same functionality?
Another idea would be to probe each 4 corners and then tell the user to rase or lower each corner manually (via LCD commands) (The cube Pro does this)
