Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
General
M505 ROD_RADIUS is not set to default factory settings.
sandro730
March 2016
in
General
Good Evening
Repetier-Firmware 0.92.8 version
I use
M502 for revert to the default factory settings.
but the ROD_RADIUS is not set to default factory settings.
Is a mistake ?
thank you
Sandro
sandro730
March 2016
Because in Configuration.h is recommend set it to 0 "CARRIAGE_HORIZONTAL_OFFSET" and "END_EFFECTOR_HORIZONTAL_OFFSET" ?
thank you
Sandro
/* =========== Parameter essential for delta calibration ===================
C, Y-Axis
| |___| CARRIAGE_HORIZONTAL_OFFSET (recommend set it to 0)
|_________ X-axis | \ |
/ \ | \ DELTA_DIAGONAL_ROD (length) Each move this Rod Height
/ \ \ is calculated
/ \ \ Carriage is at printer center! |
A B \_____/--------------------------------
|--| END_EFFECTOR_HORIZONTAL_OFFSET (recommend set it to 0)
|----| ROD_RADIUS (Horizontal rod pivot to pivot measure)
|-----------| PRINTER_RADIUS (recommend set it to ROD_RADIUS)
Column angles are measured from X-axis counterclockwise
"Standard" positions: alpha_A = 210, alpha_B = 330, alpha_C = 90
Repetier
March 2016
Thanks. Problem is fixed now.
Sign In
or
Register
to comment.
